Hi all,
I'm building a PC for a friend's daughter. I'm very comfortable building PCs and work within IT but this has be stumped. Spec below:
AMD Ryzen 5 5600G CPU
Gigabyte B450M DS3H V2 Motherboard
Crucial Ballistix 3200Mhz 16GB RAM
WD Blue SN550 500GB NVME M.2 2280 PCIe Gen3 SSD
Corsair CX-F RGB Series 650W 80 Plus Bronze Fully Modular PSU
All went together fine without any issues except..... it won't POST at all. CPU fan spins, motherboard lights up, no beeps from the speaker and no output from either the DVI or HDMI port. So far I've tried:
* 2 different monitors
* Changed PSU
* Removed everything plugged in apart from video and power, inc internal connectors like HDD LED, front USB etc....
* Tried without RAM, with only 1 stick of RAM
* Removed NMVe SSD
So I'm left with a PSU connected to the motherboard and CPU, with just power and DVI plugged into the machine and I'm still getting no output, beeps etc.... My only thought is the CPU is only supported from BIOS F61 which was released about 6 months ago, maybe the stock was old and it has an old BIOS - but how can I check / update without a valid CPU? I'm not even sure if what I'm seeing is what would happen with a BIOS that doesn't support the CPU though.
That leaves me to think it's either the motherboard (which lights up) or the CPU (fan spins up)..... how do I get about diagnosing that? I don't have another CPU or motherboard to test?
* Changed PSU
* Removed NMVe SSD
