- 27 Mar 2013
Leeds I think, we're near hullGetting a 7kW charger primarily to make benefit of cheaper overnight rates is a bit of a false economy, given the £650 install cost would otherwise fund 5,000kW odd of energy usage which at 13p difference (18p vs 5p) is ~12,500 miles until you break even.... I think! And that's if you ONLY do your charging during an off-peak, 5p rate.
Where is your nearest public charger, and nearest Tesla supercharger, @theone8181 ?
. I've got an install booked as you guys are right, at somepoint the mrs will get an electric car (she quite likes the mach e), and I guess capacities are going to go one way. There isn't actually any charging points at work yer, the directors have budgeted 6 grand for 7 pints (of the stand alone type, this warrants a double
).That pic above explains why none white is hard to come by
.The guy who says it's stressing his wiring though is making me
as there isn't that much that's power hungry unless you have several electric showers or your house is wired with Bell wire.
and doubt I'll use the heated steering wheel
