You will be upgrading from a 3350g to a 3600 which should give you a increase between 10% to 20% in fps.ok great thank you. so do you think they will see a noticeable difference in FPS if we upgrade to from the NVidia 1660 to the 3600?
i actually ordered seagate barracuda 2tb hdd the other day, is that the wrong thing? should it have been 1tb nvme? (did i mention i have no clue)
Thank you.
2tb hard drive isn't what you need, is your 240gb ssd an m2 drive or a standard ssd ?
Download speccy its a good system information program and check hard drive, then tell us.Oh. Thank you. I'm not sure. How would I tell please?
Keep windows as is as long as its on the 240gb ssd just plug in new nvme drive you may have to initialize the drive in windows disk management which will assign a letter to the m2Ok ive just checked and that socket is empty.
I will download speccy shortly (teens using pcs for homework)
With the nvme, do we need to move the operating system from the SSD to this new one?
Or is it just plug and play?
Thank you all again for your help and guidance
Make sure the pc is turned off and disconnected from the wall before installing the m2 drive there should be a screw to hold down the other side.Thank you.
Would you be happy/kind enough to provide an idiots step by step guide to do this ready for when it arrives please?
My husband will be able to put it in, but it's the installing/initialization that we have no clue whatsoever
Tx for clarification.@mickyflinn Should still be fine going for the 3600 as both the 3350G and 3600 require F40 bios which the board would likely already have to support the 3350G.
Good spot on the board being different though.
Guide but there are loads just Google.
https://docs.microsoft.com/en-us/windows-server/storage/disk-management/initialize-new-disks
Is windows on the 240gb ssd which would be the c drive ?
Your Link wants to log in to one drive.
Use the quote button to reply please.
@amy kemp alls good you don't need a bios update so yes you want a ryzen 3600 and a 1tb m2. When changing the cpu run your computer for 5 mins then turn off this will loosen the cooler and be careful with the cpu its easy to bend the pins. It only fits in one way
When upgrading do one thing first and makes sure it works correctly then do the next upgrade.
Sorry about all the confusion but don't want to give you bad info.
Crucial P2 CT1000P2SSD8 1 TB Internal SSD, Up to 2400 MB/s (3D NAND, NVMe, PCIe, M.2) £70
And
AMD Ryzen 5 3600 - 3.6 GHz Hexa-Core £180
Sorry for the links. I've removed them.
Just want to check the above two are the right ones and prices are ok?
yes, well spotted
