Got another pot heating as we speak!
But its ok to turn off ray tracing when it suits your agenda. Can you tell me, if you don't work for AMD then why are you such a fanboy and what have Nvidia done that you won't consider having one of their cards. I've had Intel/Amd/Nvidia hardware over the years and have no loyalty to any of them, I buy whats best for me at the time. So at the moment its a Amd/Nvidia system but could change next time I upgrade.
SAM is not the same thing as DLSS, it can't even be compared with RT. Many times disabling RT makes sense because there are still a lot of cards capable of 1080p or 1440p gaming without RT ( for example Pascal and RDNA1 cards).
When you can't address the points made, attack the person. I knew I should have put a trigger warning on that post above, even though I deliberately choose my words very carefully in that post you quoted.But its ok to turn off ray tracing when it suits your agenda. Can you tell me, if you don't work for AMD then why are you such a fanboy and what have Nvidia done that you won't consider having one of their cards. I've had Intel/Amd/Nvidia hardware over the years and have no loyality to any of them, I buy whats best for me at the time. So at the moment its a Amd/Nvidia system but could change next time I upgrade.
If yopu enable AMD SAM then enable ReBar for Nvidia; if the gains are equal , then i must ask, why turn if off in the first place?
Hardware unboxed (HUB), just like techpowerup (TPU), disable Smart Access Memory (SAM).
SAM adds 10-20% performance in this game from my testing.
I'm not sure why they choose to disable it when it is enabled by default and they use Ryzen processors.
SAM has been disabled for HUB since their first 6800 XT /6900 XT reviews, TPU the same. That affects all their results for every graphics card review and game benchmark they do. Something to remember when you look at their results but this is often overlooked.
Meanwhile, the following sites have RDNA2 ahead in Halo and they test the same open world demanding areas online (like HUB) which represent a worst case scenario. They are using the Steam version of the game according to the testing notes.
It is not clear if Kitguru used ReBar, but the others had SAM/ReBar enabled as there is no logical reason to disable it for AMD graphics cards.
https://www.computerbase.de/2021-12/halo-infinite-benchmark-test/
Haven't seen to many benchmarks for the campaign as of yet. This is the only one I've found so far. Was wondering how everyone else is doing with this title?
Haha, scam exposed
