AIO for 1700 recommendations
15 May 2012
Louth, lincs
Pretty much as title, looking for an AIO with the best performance to cool a 12900k. Also would like it compatible out of the box. Noise not really an issue and also RGB is not important. Thanks in advance
Overclockers provide free skt 1700 bracket with most of there aio coolers, check free items at the bottom of each page.
As for cooling the 12900k a 360mm aio if you can fit it in your case , arctic freezer offer the best value to performance as they have a thicker radiator so check clearance.
What's the max cooler you can fit in your csse ?
https://www.overclockers.co.uk/arct...ormance-cpu-water-cooler-360mm-hs-07d-ar.html
been looking at this case https://www.overclockers.co.uk/lian-li-pc-o11-dynamic-midi-tower-white-window-ca-76t-ll.html
