Is a rear window heater fuse likely to be a constant 12v live?
Fairly confident that the rear window heater F53 fuse will be a switched live and it seemed to work that way though she's mentioned the car seemed sluggish to start today. Perm. live is using the 12v sockets fuse F40. (2016 Audi A3.)
Aside from parking mode running the battery low and/or failing to shut the camera off at the 12v limit set perhaps it's not?
I'll switch it to F26, seat heating, if there isn't a consensus! thanks.
https://fuse-box.info/audi/audi-a3-s3-8v-2013-2018-fuses
