- 3 Apr 2020
Hey All!
So have a Corsair Spec Delta Case that came with 3x RGB Fans that are chained and connect to a 4pin RGB header. Issue is the Asrock Z170 ProS board I was planning on using doesn't have a 4pin or 3pin header. Ive looked for a 4pin RGB Controller that may then plug into the reset button but cant find one.
Any Advice guys??
Any Advice guys??
