Best used macbook
14 Jan 2022
Cheshire
Hi
I have an early 2015 13" MacBook Pro but sadly the screen has almost packed up
I got a quote from a Mac repair company of £540 to replace the screen so I am considering buying a newer model but I dont know which one to choose and if they are better or worse
Its my main laptop and I mainly use it for coding and mainly at home not carrying it around
They have suggest the following
MacBook Pro 15" 2018 Touch Bar, 2.2 Ghz Intel i7, 16 GB RAM, 256 GB SSD (fast drive) Retina Display £900
and
MacBook Pro 15" 2017 Touch Bar, 2.9 Ghz Intel i7, 16 GB Ram ,500 GB SSD (fast drive) Retina Display £800
Can anyone tell me if the repair costs are fair and what alternatives I should be looking at
Thanks
Peter (Cheshire)
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
8 Oct 2020
I'd also suggest looking at the Air. Within budget (look around for deals) and it's future-fit.
The base model only comes with 8GB or RAM so I'd suggest looking up some reviews to determine whether that's good enough for the type of work you do. Alternatively, 16GB upgrade is probably a good investment for anyone doing more than basic office work.
5 Jan 2004
Every now and again you can pick up the M1 air base model for £550-700 as a return from the rainforest warehouse if the 16gb is too much.
OP
14 Jan 2022
Cheshire
Thanks for that. I meant returns but yes that looks nice
What I am unsure about is as its my main laptop now would the 15" be better for coding workspace
Of course I would have to sacrifice the weight difference
