Intel will get this locked down with a bios update like they have done before.
Sadly if you can't use anything other than a £500+ motherboard it makes it utterly pointless. Let's hope there are more/cheaper DDR4 boards that support this feature, and we can all enjoy some actual overclocking and tweaking again, not just buy the most expensive CPU, RAM and board the add 200MHz and be cheering about how totally awesome it is, when it really isn't.
Plus the amount of cooling needed to hit over 5GHZ.
I am a bit out of touch and confused. I just purchased a 12700k and posted in a forum for my motherboard about best way to overclock, as my 6700k is overclocked to 4.5 and that's what was the norm.
However all the replies were "it's not what you do anymore" or "it's not worth it"
It's not that bad on the P-Core only CPU's, I guess a lot would also depend on the lottery. I think you could easily find a good balance of ~5GHz and low voltage to get a very fast, and pretty quiet system. Just need more confirmation on other board vendors, and cheaper boards.
Most likely because the power use quickly gets out of hand when overclocking Intel chips. The big +. little topology of Intel makes the gains somewhat limited as you are tuning the system for only the half the cores.
So in a nutshell I don't really need to oc my 12700k like I did with the 6700k
