I'm actually in the process of buying a new build (not started building yet just in the early phase, yet to have my first meeting with them about options etc)
Issues that I am referring too are including but not limited to
I've been searching for months upon months for something reasonable and I keep getting outbid on properties where they are going for a stupid amount of money for what you get. Eventually settled on a new house instead that has been reserved to me if I choose to go ahead with it. Been to see the build I chose that was almost complete for a different customer and its lovely size and from what I could tell had been finished to a decent standard couldn't see a fault in the plastering, the sealing no damage anywhere I could find (I had a good inspection as the guy let me walk around freely while he was busy)
- New houses are generally overpriced for what they are
- Cheap materials and low standards compared to older houses (this depends on the company/development but you get the idea they are all as bad as each other). The developer I am going with has a horrible reputation, but so do the rest of the "budget" ones.
- Options/Finishing touches are EXPENSIVE, the house I'm trying for only comes with cooker, extractor fan and gas hob as standard, you are buying a skeleton. Everything else including the back garden grass, flooring inside etc is extra, it can add up quickly (I would be getting my own company doing the flooring for half the cost). Something as simple as having a tiled bathroom isn't standard and has to be paid for. I have the options brochure and my god its frightening how much they can charge for a simple integrated fridge and something as simple as putting downlights in/extra sockets. I'm expecting a big shock when I have my options meeting along with trying my best to get stuff thrown in for free.
- Estate management fees (clean up, maintenance etc) that they often hide away from people (depending on the development)
- Shrinkage and cracks with the house settling along with other snags you need to be on the look out for during the process and after
Its just a stressful time!
Is there a reason you've gone for a new build? We've been looking at one as first time buyers because of the incentives but they are all just ghastly looking. Absolutely no character and generally just so poorly built.
I think the house we're offering on is less than 100sq.m in total!
