- 6 Jan 2013
- Rollergirl
I'm currently putting together a home cinema setup and this is the system so far:
Denon S760 amp
Dali Spektor speakers connected to front L & R
Dali C8D subwoofer
Samsung TV connected via HDMI plus optical cable
PS5 connected via HDMI
The issue I have is that I can't get any subwoofer output. When I go through the amp test & config setup then I do get subwoofer output so I know it's getting a connection, but it seems to be disabled when I exit the setup menu. I've been toggling through all the sound modes but no change. The sub is connected according to the manual, i.e. a single RCA cable between them - pre out 1 on amp to LFE on sub.
No doubt it's something simple I'm getting wrong and would appreciate some help!
TIA
Denon S760 amp
Dali C8D subwoofer
TIA
