Since I had my 3090FE replacement from RMA, the fan-stop function is really inconsistent.
Wondering if anybody else has had, or currently has issues with fan-stop?
Basically it seems my card barely ever stops its fans. The most reliable way to trigger it is to let the display go to sleep.
If I wake it up after that, the fan will stay stopped till the next time the GPU is loaded. Then again, it wont stop.
Sometimes it stops when I connect to my work Virtual Desktop (which is a near full screen window) and other times it wont.
I thought it was software related at first, and went and re-installed just about everything I could think of, from drivers to Afterburner to MSI centre and HWInfo. It would sometimes be the case where after I re-installed some one of these applications or drivers that fan-stop would work right after. But then after a gaming session it wouldn't kick in again.
I just tested with a clean Windows 11 install, with nothing installed but the drivers and steam, and same issue :/
Using latest 511.23 drivers.
I run a single monitor at 3840x1600@144hz. I have found topics where people with multiple monitors had this issue.
So I am curious if anybody else has had this?
