- 20 Jul 2007
- A sunnier or damper area than Ron-ski....
Ok folks,
Got two Quest 2s and looking to set up wifi connection to PC today so I can test higher resolution game play and the like.
Just wanting to check how I do this as some of this involves buying apps/software, so don't want to waste money!
Done so far:
- Have set up both Quests already through Meta store
- Have just installed the dedicated Asus Wifi 6 AX5400 router I bought based on your recommendations for this and set up a unique wifi network for this
- I've positioned it in the lounge (so it'll be about 1.5 metres from the VR sets when being played), connected to the CAT6 ethernet cable that runs through a couple of switches to the upstairs where both PCs are based.
To do:
- I've seen a few folks checking the speed that the wifi6 is running at, not sure how I do this in ASUS' app? Or do I do this through the headset?
- Next I 'think' I need to buy two copies of virtual desktop for each headset - this I believe will let be connect to the two PCs remotely through the VR sets. Although I've seen different apps recommended
- Then I guess I can run steam VR or something through these to then play games?
As you can see I get fuzzier in the to do list - any pointers appreciated!
Done so far:
To do:
