- 18 Dec 2008
I am having difficulties with my home network.
I have 5 Windows PC’s a mixture of Windows 10 & 11 Pro O/S’s.
The problem is I cannot remote desktop 2 of the machines (PC 1 and PC 2) or share files from them within the explorer network folder. It keeps telling me my credentials did not work. However, I can RDP the other way from them to the 3 working ones. All the machines are configured to be in a private network and discoverable. It’s as if they are not communicating over the network.
The only reason I bought Windows 10 & 11 Pro keys was to be able to use RDP, so I am a bit annoyed.
PC 1 is a Windows 10 Pro laptop recently installed with all current updates.
PC 2 is a Windows 11 Pro desktop with a fresh clean install of Windows.
I have exhausted searches on google for a solution. Does anyone have any suggestions?
The only workaround I can see is to use TeamViewer instead of RDP.
Thank you in advance.
names and ip addresses have been modified.
