Yeah but only 2 unless you want to pay silly money where as Z690 comes with 4 even on £200 boards.Don't all x570 boards have PCIE4 M.2 slots?
Depends on use and budget whatever 6 core plus cpu you buy now will last you for 5 years..
So I guess the question is... what (in your opinions) would be a processor that would give a good 5/6 years of usable life?
Sorry All I forgot to reply to this thread... I have to it admit, it went a bit off tangent lol.
Ill be honest, I think I worded my initial question wrong. I am not so much concerned about near future upgrades or such, but I am looking for a processor that I can buy now that will last as long as my 5820k has done, so roughly nearly 9 years and still is a decent runner.
Now I am aware that parts can change and grow at an exponential rate and what lasted 9 years then may not last that now.
£800 will get upu 12700k, z690 motherboard and 32gb 3600mhz memory but you will need a cpu cooler or skt 1700 bracket for you existing cooler.Oh Yea sorry forgot that, cant recall what the 5820k and asus x99 mobo cost me back in the day... but say maybe 800 total for both processor and mobo? Ill be honest, ive recent started full time employment again after a bit of a dry spell so could push that if needed.
Im not looking to buy the best all out system, just something that will last me a good chunk of time.
When picking between processors last time it was between the 5820k and the 4790k which.... in hindsight, the later may have likely been the better gaming processor and would have lasted me just as long. Cant recall why I settled on the 5820k, I think it was just newer?
Memory good.Aaaaaaand now I remember the main reason for going for the 5820k, DDR4 Memory!
Wont need memory, my old ones packed last last year and bought 32GB Corsair Vengance 3200MHz to replace so that should keep me good there I think? So I could put the cash into either of the mobo or processor.
Thank you for the replies so far people, the input has been very helpful
Thanks!
a lot of people have mentioned the 12700k and I see it popping up quite a bit in other topics so this is likely the most serious contender
What would be a good future proof CPU to buy atm? Or at least a future proof architecture?
The Core i5 12700K or Ryzen 7 5900X.
That's what I did, moved to 5900x 12 core and will last me a good long time.
The LGA1700 socket once you go 12700K will have little to no real worthwhile upgrade option, only something marginal at best, so I am not sure why you go for it, unless you actually don't want a 'future' proof platform, just the best CPU/£ for performance in games (at the higher-end) in the present.
It seems you are really just shopping for a new PC or motherboard/CPU combo, using 2014 DDR4 RAM which is now on it's last legs. You said you went 5820K as it was DDR4, that was 8 years ago, now DDR5 is coming in as the new option, albeit expensive, but some was DDR4 when it first came to market.
If you really can't wait till the end of the year for more options and DDR5 prices to fall, then jump right in with a 12700K, but it isn't future proof, it is just another system you can own for a while.
Power consumption, heat dissipation and overall TCO is important. Because the Intel CPUs require more expensive power supplies, more expensive water cooling units, more expensive noise dampened cases, etc. They are just unpleasant to own.
That's the way I read it too, the OP just wants a system that will last 5 or so years. As he's still on a 5820k, he never took the opportunity to upgrade to say a used 5960X so I'm not sure he's that concerned about drop in upgrades.
They should probably edit the title and opening post then, otherwise it is just another spec me thread.![]()
Yeah, he'd be better off posting in the New to PC gaming & upgrade advice section. Helps to avoid some of the resident fanboys of this section![]()
OP, make sure to ignore stuff like this though. Pure fanboy nonsense from a resident troll.
