More than likely going to get worse.These prices might last years
Or it might even get worse
Interesting post on outfox the market on Facebook, if you use 100% renewable (which must on be the leccy), why is the cost of the leccy going up.
Nearly same as me.
I also fixed in October until August 2024 with Scottish Power. My tariff is a about 0.1p a unit more expensive. In hindsight definitely the right decision.
Not looking forward to seeing what 2024 has in store. 3 year was longest fix I could getThese will most likely be the new prices going forward, don't expect them to drop back (they may settle a little bit but more likely to keep rising) same for diesel/petrol food etc, that's inflation and a constant strive for growth and profits for you.
That standing charge rate change is ludicrous!
i asked a few pages back. Basically 100% green energy is a myth.
Err, that’s actually how it works - if I go to a green supplier and buy electricity from them, they put that energy into the grid in one location I take it out in another. It’s all the same grid the length of the country.There is no way to separate the energy you pay for from the energy production facility that is closest to you (multiple points of origin for production all feed into the same grid), Although your provider may purchase 100% renewable the feed to your property will be from the nearest power station, Unless you fancy installing hundreds of miles of cables to the nearest hydro/solar/wind array directly to your property then you have no chance of this ever being a thing.
The problem with green electricity is that they still need to cover for supplying you when there’s no wind by paying for conventional base load and over supplying when there is wind.
Electricity isn't like water, it doesn't flow in and the flow out at the closest point - generators put energy into the grid, unless there's operational reasons to isolate particular sections of the grid, all a user is doing is taking energy out of the grid. The energy isn't traceable to any particular generator.Your energy comes from the closest source, in my case based on my geographic location my power comes from Hinckley point nuclear power station.
My supplier might buy green energy with the money I give them but the energy I consume is from nuclear i.e. not green sourced.
Go on explain my job of 22 years to me again then please?Electricity isn't like water, it doesn't flow in and the flow out at the closest point - generators put energy into the grid, unless there's operational reasons to isolate particular sections of the grid, all a user is doing is taking energy out of the grid. The energy isn't traceable to any particular generator.
So you think you can tell where your electricity comes from by measuring "something" at the socket?Go on explain my job of 22 years to me again then please?
Do you understand how path of least resistance works? Your power is provided to your property by all sources local to you, properties and networks are built using grids and grid isolation so as to not over saturate an area. Sub stations are how each gris is powered and isolated. They receive power from the main national grid that receives power from all sources, you closes source being the point of lease resistance will be the one providing 99% of the energy to your part of the grid.
No don't be pedantic, although every generation platform has a very specific generation signature.So you think you can tell where your electricity comes from by measuring "something" at the socket?
Well that is the entire point though from the National Grid point of view when generators are sync'd together.No don't be pedantic, although every generation platform has a very specific generation signature.
"we are all in it together" MPs can claim heating and utilities on their expenses![]()
