- 1 Sep 2013
Er, Warhammer 2 had the option when you set the game up to either have The Chaos Invasion or not, you had that choice in-game without the need for any mods. And you could choose what difficulty level to set it at if you wanted it on.
Not sure about 1, can't remember that far back.
Anyway, bought the game and only played for about half hour or so before work today, am off tomorrow so will get on it then. Is the prologue worth playing? I mean, I don't need help with the game having played every TW game ever made, but is the story good enough to play it?
pretty sure that option was added later i remember using mods to add the chaos invasion later in game or off completely
