Michelin has just launched the new Michelin Pilot Sport 5, and it looks to be a very interesting, but perhaps not what we expected, update!
First up, some general information to clear up some confusion online. This tyre is not a replacement for the Michelin Pilot Sport 4 AND 4S. The Michelin Pilot Sport 5 (PS5) directly replaces the Michelin Pilot Sport 4 (PS4), and while there's been no official announcement about the replacement of the Pilot Sport 4 S (PS4S), it is likely this will be replaced at some point in the future.
Just ordered up a set of Goodyear Eagle F1 Supersports for my e87 130i. Costco have an offer on for Goodyear tyres (17" and above) so fully fitted for a pair of 225/40/18s on the front and a pair of 235s on the rear came in at £343![]()
They are superb tyres and are absolute bargains. I used them on track on my CTR the other day and they absolutely smashed it, considering they are meant to be primarily road tyres. Great sidewall thickness, great feedback, great resistance to overheating and excellent grip.
Just crossed 4000 miles on my Crossclimate 2, I rotated them last week. Fronts were on 6.2mm from 7mm and rears were on 6.7mm from 7mm after I gave them a proper measure. Seems they wear fairly quick from new in the warm conditions, but seems they stabilise once they're getting a little lower and in the colder temps. Just typical that this winter has been very mild. Usually by now I'd have had to have driven in numerous snow days.
Yeah I bought a set of all-seasons, cue the weather being practically spring like for most of the days since :s
Conti Cross Contact?Before I default back to Pirelli Scorpion, does anyone have a recommendation for a tyre in 255/50R20 to go on a Range Rover? I'd love to be able to fit Michelin CrossClimate but they don't appear to be made in the right size. I'm not sure if I could fit a slightly different size tyre to give me a better range of tyre choice?
Continental UUHP tyres have always been excellent...until they've worn out 50 miles later and you need a new pair
Very highly rates the new Conti Sport Contact 7’s.
Continental UUHP tyres have always been excellent...until they've worn out 50 miles later and you need a new pair![]()
Bought Goodyear Eagle F1 Asymmetric 5 225/35R19, great tyres, the grip in the wet is such an improvement to the Nexen that the car came with. Skoda 3.5 VRS
I guess that remains to be seen, how quickly they wear.Continental UUHP tyres have always been excellent...until they've worn out 50 miles later and you need a new pair![]()
