@Nexus18
At this point your trolling me with your repeatedly asked questions that Iv'e already answered multiple times now.
If you scroll down the problem list, the 'Experiencing a higher rate of stutter / FPS drops when the HD texture pack is installed' link:
Using logic to pick holes in other peoples extremely weak arguments is now called trolling?
Also, no you haven't
answered all of my questions, either you won't or more likely you "can't" because you have no way of being able to go against them, for example, still waiting to hear your thoughts on why there are "some" 3090 users reporting fps drops?
If you actually go and read through the threads, you will see there are various people reporting issues regardless of resolution, settings and specs, funnily though, the vast majority are nvidia users but lets also ignore that shall we.....
The very "fact" you said you get this even at 1440P with FSR and NO HD texture pack after some time shows there is an issue on your end or/and the game.... Let's take a look at the recommended specs for no HD texture pack shall we?
			Recommended 2K configuration (60 FPS, Raytracing On)
Operating System Windows 10 (20H1 version or newer, 64-bit versions)
Processor AMD Ryzen 5 5600X @ 3.7 Ghz or Intel Core i5-10600K @ 4.1 Ghz (AVX, AVX2 and SSE 4.2 support required)
RAM 16 GB (Dual-channel mode)
Video card AMD RX 6900XT (16 GB) or NVIDIA GeForce RTX 3070 (8 GB)
DirectX DirectX 12
Hard Drive 60 GB available storage
So even though you exceed the requirements, you still encounter the issue after some time? But surely since you exceed the requirements, you shouldn't be having issues? Right?
Funnily, it's rather ironic as over the last 1-2 weeks on my project (whilst completely different scenarios, it will be much the same for "game" development too), we have been dealing with a performance issue for an app in production, essentially end users complaining about sluggish experience/non-responsive at times, RAM usage was pretty much maxed out, as per usual, the initial thought of everyone is oh, just add more RAM.... despite the fact that we had already done this 3 times in the past before and was far exceeding the requirements not to mention, the amount of users was limited.... so with some proper investigation i.e. monitoring and checking log files and some testing, turns out it was an issue with the "application" not managing nor clearing allocated RAM after processing of said files and usage, needless to say, we got this fixed the "proper" way by having the developers fix this on the "app" side. I would say given that the initial game released with a 16GB VRAM requirement and after said patch, dropped to 12GB VRAM, it sounds like a similar story here, at least with either the game or/and peoples configurations since it's not happening to "everyone" hence the lack of reports not to mention, not a single reputable tech site/journalist stating it....
			Unfortunately a par for the course, a carbon copy experience months ago. I am yet to see any debunking of anything over months just spades of text with hyperlinks losing purpose as the point is lost among the waffle. One has to ask if it was a mistake the pack was installed by said person or they wondered post installation why the game was broken.
*yawn*
Still no substance at all I see
You do realise all those "hyperlinks" that you don't bother to read contain "evidence" to back up the points, right? Just like when the developers stated that they had found the issue with the texture loading/rendering and working on a fix..... Unlike your posts, always nothing worthwhile to add at all.
If your last bit is referring to me and my FC 6 experience, again, if you actually read the posts and processed what they were saying as well as retaining knowledge, you would have clearly seen my screenshots, posts etc. right from the launch of the game where I was having texture rendering issues to it being fixed with the pack as well as never facing the same fps drops that Tommy has got "unless", I enabled rebar, didn't use FSR, max settings at 4k.
https://www.youtube.com/channel/UCRyIQoB0h4lyiB68jTNlOPg
But nah, lets keep the fingers in the ears and only believe what you want to believe
			The roughly marked out red lines on the map, is there anything you need to do to capture that area etc.?
You need to destroy the military bases, checkpoints, looks like artillery, cannons and gates.
