- 19 Feb 2007
- Northampton
Just curious if anyones heard of a potential Quest 3 with increased FoV, Res etc... I had the Quest 2 but the low'ish FoV was a massive turn off.
Not sure if psvr 2 will affect Quest 2 sales....overall it's a much bigger investment needing the console alongside the headsetAs said above I think it seems Cambria is next, which isn’t really a Quest 3.
There has been nothing out of Oculus regarding a Quest3 other than them saying Quest 2 will have a long life… I think probably their focus for the quest will be to drive costs down to make it as accessible as possible, then they can leave Cambria to cater to those that want more and are willing to pay.
I imagine however that a Sony PSVR 2 (perhaps at the end of 2022/early 2023?) will start to significantly dent Quest 2 sales, so they will likely want to have a Quest 3 out before too long after that.
Intrigued at all these headset haptics and how comfortable they'll be in practice and if they'll actually add much to the immersion or be really off puttingCambria taking cues from Sony:
https://youtube.com/shorts/q8sAJhmQKaA?feature=share
Facial haptics in Cambria pre-release units.
My 2 cents worth...I was also intrigued by these and thought I'd give one a test. I went for the Subpac as I could use it for more than just VR and appeared to be more powerful than the competition. It's probably just as well I did that as I use it least in VR and prefer to use it for music and movies. I wholeheartedly recommend it if you're going that route.
It's comfortable to wear and it massively adds to the immersion in games although it's a bit of faff depending what type of game you're playing. If it's a seated game then it's brilliant and I wouldn't hesitate to put it on. In DCS I can feel the jet engine in my chest and the plane feels alive, in Battlefield the explosions and gunfire is felt...with some degree of power as well. My main gripe with it is the additional cables if you're looking to play a game which requires more dynamic movement. You then have to become far more conscious of the additional cable. This could just be a personal issue as I have a Frankenquest 2 with the Vive Deluxe Audio Strap so I'm not even used to having a headphone cable and now have 2 audio cables (1 line in, 1 headphone line out). It's also not something you want to be passing between people in a game like Beat Saber as it really needs to be dialled in to the individual user. The fit is important and it took me a good bit of time to dial in the fit to ensure good contact for the transducers.
Whilst it can be a faff with the cables in some games, it's one of the best enhancements to my audio and gaming experience in years. I've not let too many people try it out in games although anyone I've let listen to music with it on has had an involuntary screwface whenever the bass first kicks in. It is genuinely like having a subwoofer on your back. I'd be reluctant to go for something less versatile like the Bhaptics thing although I can appreciate that it offers a different experience in the limited games which supports it.
As a result of kids and neighbours I hadn't appreciated the bass poverty I'd accepted over the years although since getting the Subpac I'd gladly get a replacement or upgrade when the time comes.
Very cool! I have definitely been looking into the subpac for a while and will probably eventually pull the trigger, heard nothing but great things and your recommendation has only added to itMy 2 cents worth...I was also intrigued by these and thought I'd give one a test. I went for the Subpac as I could use it for more than just VR and appeared to be more powerful than the competition. It's probably just as well I did that as I use it least in VR and prefer to use it for music and movies. I wholeheartedly recommend it if you're going that route.
Whilst not quite the same I had the Razer Nari Ultimate for 2d Gaming and its a marmite type of headset. I loved it feeling the explosions and rumbles on your head but some people hated it. Only reason I got rid was the battery life got worse it was fine at first but after about a year it would last 2 hours then need charging. Going back to normal headset after that took me a while to get used to it again as it was so flat.
Very cool! I have definitely been looking into the subpac for a while and will probably eventually pull the trigger, heard nothing but great things and your recommendation has only added to it![]()
I had guessed we were going to see a Quest 2 (lite/pro) with upgraded lens and display,smaller etc, then the higher end pro-sumer Cambria, and possibly Quest 3 after that. But, its almost too late now for a Q2 Pro IMO at the very least it should have been announced. I reckon chip shortages/costs are making it unfeasable, the hardware is getting on a bit and really could do with CPU/GPU upgrades and by the time they do that its going to be too expensive and they may as well just sell the cambria unit.
