No, but am using the same panel.Anyone else got any experience of EARC, Atmos and a 6900XT?
Connected to my LG CX, whatever I try to do it won’t let me configure Atmos, just says device does not support. Pulling my hair out.
I have the same problem with a bx and it worked fine on an nvidia card with the same setup. I didn’t find any solution though.Anyone else got any experience of EARC, Atmos and a 6900XT?
According to this guy - https://community.amd.com/t5/graphics/rx-6900-xt-and-dolby-atmos-via-earc/td-p/443428Annoying. Worked perfect with my 3070 last year. I will give it one more shot and reset the TV settings.
Good work CSI mof, some helpful suggestions in that thread.According to this guy - https://community.amd.com/t5/graphics/rx-6900-xt-and-dolby-atmos-via-earc/td-p/443428
Resetting the tv and reinstalling the drivers worked. Haven’t tried it myself.
The MSI Gaming Z Trio is going for a good price at the moment and it's using the higher quality XTXH chip, so that would be my current recommendation.
If you have a problem, return it within 14 days. The card should run fine at stock AFAIK with the default power limits. If you are looking to overclocking and use high power limits, I'm sure it'll throttle.Hi again. Was just about to buy one today until I read on reddit that apparently the QC is dodgy and the card suffers from poor hot spots due to cooler having lack of heat spreaders... posted by multiple users on multiple different threads, though some users were commenting about the x rather than z. My understanding is that both use same cooling... this suddenly took the wind out of my sails.
Any thoughts or comments?
Cheers.
Thanks, wouldn't be overclocking, just leaving everything at default was my intention. Are you using one yourself or did you go with another brand?If you have a problem, return it within 14 days. The card should run fine at stock AFAIK with the default power limits. If you are looking to overclocking and use high power limits, I'm sure it'll throttle.
No, not using one myself. II went with a Toxic so the other end of the expense scale but I like to overclock so wanted a 6900 XT with a AIO for the best temperatures and overclocking headroom.Thanks, wouldn't be overclocking, just leaving everything at default was my intention. Are you using one yourself or did you go with another brand?
Keyboard can't get me into the bios at this point and it just shuts down.
Any ideas?
@Biffa - Try clearing CMOS and clearing power to the system for a minute.
Furry muff.Thanks LtMatt. Yeah I used to overclock, but these days I just want to plug and play. Got my eyes on an ASUS offering at the moment. I think with both the PS5 and XSX using RDNA2, the 6900XT is where I should be heading, rather than Nvidia.
On a separate note to everyone. If anyone is using an ASUS 6900XT, please let me know your impressions. Also if anyone has one of these hooked up to a 120Hz TV (I've got a high end Sony Z9J). Please let me know if all runs without issue.
Thanks all.
Nice one.Did the trick, got back into Windows, but couldnt load radeon software as device was disabled in device manager. Re-enable, rebooted and all working again.
Wierd.
I had the X and returned it as it did run hot. Went with the Red Devil instead. In hindsight I could have kept the MSI card as I eventually went down the custom loop route.Thanks, wouldn't be overclocking, just leaving everything at default was my intention. Are you using one yourself or did you go with another brand?
