It isI was under the impression the line under dual motor was red for performance models
That’s what I was looking at, but as my numberplate is shorter (6-digit plate size) the plate isn’t wide enough to cover the original plastic mounting plate. I’d have to cut that down to make it less wide.I’ve had my plates stuck on with Velcro which allowed me to ditch the outer frame and mount them on the original plastic bumper piece. There’s pics in this thread.
Put them back to stock now as I’ve ordered a replacement car and Jesus h it was hard to remove the Velcro from the plates. Safe to say they’d have easily lasted the life of the car.
Just a randomish thought I had. When I charge my car (performance) to 90% I get an estimated range of 250 miles. How do I compare this to the as new value (I.e. is there just a value to use), as the 350 miles or whatever rhe "official" range is, is just rubbish imo.
My car is currently sat at 90% and the energy display is predicting 265 miles or there abouts.Just a randomish thought I had. When I charge my car (performance) to 90% I get an estimated range of 250 miles. How do I compare this to the as new value (I.e. is there just a value to use), as the 350 miles or whatever rhe "official" range is, is just rubbish imo.
It depends on the journey, the conditions and how you drive too. The range is unique to everyone.Just a randomish thought I had. When I charge my car (performance) to 90% I get an estimated range of 250 miles. How do I compare this to the as new value (I.e. is there just a value to use), as the 350 miles or whatever rhe "official" range is, is just rubbish imo.
Oh I realised not long after I got the car, I just wondered what my actual degradation is. I've not as it's been steadily getting warmer my average usage is dropping, started at 370 when I got the car in Dec, now down to 340/mile.The "official" range as you say is exactly that, under lab conditions etc, the same as MPG for ICE cars. It's for comparison, not real world.
If you've only just realised that then I'm sorry.
@TheOracle, yes I’ve considered it, the problem I have is the visible difference between a PPF’d panel and a non-PPF’d one. That means I’d have to get the whole car done, which is £££.
I’m getting a hard ceramic coating done which should go some way to adding some protection.
The way I look at it is, if I need the sill and arch redone in a year then the 3rd party paint might be stronger, and it will look better than PPF.
It's blue. Most of the ones I've seen on Facebook have been on the arches, but it's usually black or red ones that were built in 2020. Before buying as new one I viewed a 3000 mile red one and there were lots of chips on the rear arch.Forget the sill and arch... the bumper and bonnet will need a replacement long before the sill and arch. What colour do you have? I'd bet a body shop would charge for a big blend job if you're trying to match a metallic colour.
