With older CPUs like Ryzen 3000, sure. With Intel CPUs? Maybe. No negative with Ryzen 5000/RDNA2 though, as I mentioned in my post.
I'll play devils advocate though for you. Let's image there is one or two games out there where FPS are 1-2 lower with SAM on when using Ryzen 5000/RDNA2, what about all the other games that are up to 29% faster (Forza 5) and the multiple games with 20% improvements, ala Forza 4, Halo, Horizon Zero Dawn, Valhalla etc?
You don't need to do any homework with Ryzen 5000 and RDNA2, don't worry.If you recall, support for Ryzen 3000 was added much later by motherboard manufacturers with updated BIOS.
I'll say it again, there is no logical reason to disable SAM with Ryzen 5000 and RDNA2. If you are using this configuration and can prove me wrong, please provide some clear examples, backed up with data Grim. I'll be waiting.![]()
Did you watch that HUB video?
He showed at the end a wide range of games with SAM on 6800 and 5950x:i.e. it's not a leave it on and forget setting.... as there is proof that it does harm performance and most importantly, is that it's "random" as to what setup or/and game will see a benefit or which one will see a decrease in perf. hence why HUB are leaving it off for the time being.
