Deleted member 651465
Bloody hell, you lucked in to a cracking deal if you found a house with a 6kW system and a V2 powerwall installed!
Using the powerwall in the evening/night is what I plan on using it for. You say the impact is 50%... do you use a lot of electricity? I'd have thought the powerwall would have covered all of your evening usage.
it doesn't have a smart meter presently (which seems odd for a 2017 build) so that is the first port of call as I want to get on GO.
naturally that means you need to make sure your battery system has an inverter big enough to be able to charge it during those 4 hours.
