So, how does it compare to your OLED TV? Better, worse? Can you see the pixels? Lol
I am all excited about it, yet a apart of me think I may be underwhelmed by the potato resolution and end up with a 42” C2.
Give us as much info as you can, are you blown away, will you be keeping it for sure long term or looking for something else?
So used it a bit more, quick thoughts:
LG e7 in technicolour preset (most accurate out of the box preset) and dell mon. just in default standard and HDR400 for HDR content since I'm not sure on settings yet till hdtvtest or tftcentral get their hands on it.
- no doubt dell is superior for uniformity and banding or rather lack of banding on 5-10% grey slides
- colours overall are better than the lg e7
- blacks/shadow detail is handled better than my e7
- sharpness/clarity, I do think if you're a fan of 4k and all about pixels, you might find this a bit lacking but then it kind of comes down to a 21.9 vs 4k/ar thing really (of course could wait for a higher res. 21.9 at some point....)
- text fringing is very much a non issue imo, can notice it if you look for it but you do have to be pixel peeping
- anti glare finish is great
And as we all know, it's got all the other usual advantages of oled i.e. superior motion, viewing angles etc.
As it, £750-850 and a "usable" monitor size, nothing can touch this imo so can see it staying for a long time, next upgrade for me will probably be 38" 21.9 but not in any rush now.
Also, this just shows how much contrast ratio and proper blacks makes to dark areas, don't have a comparison pic, maybe someone else can take one on their lcd though. Essentially on my ips, that back container part was completely black, no detail at all and just that area in general, I always had to turn the flashlight on to see where I was going (this is SDR mode too as DL 2 doesn't support hdr)
Have sent a service ticket now instead, annoying how character limit is 500 as can't add all the detail.....
@srekal34 any luck on the warranty front yet?
