Both look nice, but the Virpil ones really catch my eye. A bit more money than I'm looking to spend. However, going by my current form, I'd probably be better off just buying quality than buying cheap, as no doubt i'll just end up buying a more expensive set in the end anyway...
I'll definitely need Rudder control ... dammit, this is just as deep a pit as sim racing!!!![]()
If you have a Racing sim set up you can set up your racing pedals as rudders. using the clutch and accelerator bound together as a rudder axis and the brake as a wheel brake.
Google it, while its not ideal (the pedals obviously aren't on a bar/pully) it works and saves you money and you just need to remember to only press one pedal at a time.
