It will work just fine I would imagine with the standard patato textures. But install the "optional textures" and I am almost certain you will have issues.I have bought Far Cry 6 2 minutes ago since I got it for a reasonable price (£20), I will be testing at 2560x1440 with my RTX 3070, I want to see how badly it runs on my card, I think my resolution is a fair res to use since the GPU is not 4K capable in these later games so am using a realistic res and one I use personally.
I am going to work at 5pm and this won't be downloaded by then so will update you all.
I am installing those too.It will work just fine I would imagine with the standard patato textures. But install the "optional textures" and I am almost certain you will have issues.
  ), it should be fine at 1440.
), it should be fine at 1440.I think we all knew that would be the caseMy RTX 3070 was hitting 6 FPS, went to a crawl in the opening scene, I shall upload the video.
I ran it with everything cranked and was hitting 30 FPS, then I turned DXR Shadows off which gave like 0.5 FPS then turned them back on and it destroyed it.
The GPU core was being cut by the memory saturation so was hitting around 150 watts max.
8GB is not enough for FC6 on max settings at 1440P, no idea how the benchmarks have such high numbers.
EDIT, it seems HUB tested at high with DXR on... I tested at Ultra with DXR on, I mean if the 3070 can run at high with DXR there is no real issue I am losing barely any visual quality, but for academic reasons yes FC6 maxed out at 1440P cripples the RTX 3070 at 1440P which is it's sweet spot resolution.
Lol. It was obvious that would happen though to be honest
Well at least you now have evidence against some blow hards who think a 3070 is good enough, yeah for lowered settings maybe.
You get lower RT performance on Radeon or lowered settings on Nvidia, seems fair LOL.
I doubt the 3080 is enough.
It's all good, needed a game that was "Known" by the team Red guys to test and FC6 was the one.Thanks Tired.
It was never a case of us vs them or small mind thinking, it just escalates that way on forums as people lose the point of what is being discussed. Regardless of what strange agenda's spawn from it, my take always was from a hardware standpoint this is something that should not be dismissed - particularly by folk that own these cards - why get uptight over it?, just understand how it works and then move on.
What we got was pages of childish posts basically denying this is a problem. Funnily enough by a small cohort of said owners that do not want to accept it.
My concern was people picking this card up in the past year when I seen them post "this should last me a good few years" which should do as long as you don't venture into high textures or need high detail especially on demanding displays. Some people may be thinking of LG C2's or Alienware widescreens for example.
I am saying the RTX 3080 is likely not enough because most play at 4K with them, no idea about 1440P.
There were two or three threads this danced about on, one being the FC6 thread.
To give you some history - only because I too wouldn't read every page if I was later to the party, the first holla was - show me some evidence, so it took a while then a game other than Godfall came out that was popular enough to use as an example; it took about 10 months but you would expect that as these games are being created before the hardware is out.
Then once we had a game we could talk about constructively came along, the first thing that was tossed into the ring was 'game is broken', 'must be your setup', 'local system issue' etc.
Some were commenting on it and didn't even own/try the game...
Well I don't, so off you go to test it out.Do we have any stats for this?, I run 3440x1440 with my 3080, lot of people I know irl use an ultrawide like myself.
Do we have any stats for this?, I run 3440x1440 with my 3080, quite a few people I know irl use an ultrawide like myself.
