If he wants he had every right to hand the car back and full refund. That's what id do, any issues like that (simple stuff) early on isn't a good sign it's a reputable place.
Not had that for a long time for either my bike or car. I think it was written on the invoice the first time I had my bike tires changed 7ish years ago but numerous tire changes on the car and bike since and it's never been mentioned.I thought all dealers gave you a slip of paper telling you to check your wheels after 25 miles? Last time me car was in at the main dealer, I got one of these. As it was, one of my wheels started to come loose before 25 miles was up.
It's always puzzled me to be honest, if nuts are done to the correct torque then they shouldn't be going anywhere after 5 or 500 miles.
When should wheel nuts be retorqued?
When new or replacement wheels are first fitted, the person responsible must torque the wheel nuts according to the vehicle manufacturer’s recommendations. These details are included in the owner’s handbook and vehicle documentation.
After approximately 30 miles or 50 kilometres have been driven on the new tyres, the wheel nuts must be checked and, if necessary, retorqued to the same values as before.
Not every car will have the same torque requirements, however. Different makes of vehicle will require different amounts of torque to tighten their wheel nuts properly and avoid causing any damage.
This is because, after a reasonable amount of time, the wheel nuts will undergo the typical stresses and forces of a car in daily use. These stresses include supporting the weight of the vehicle, the rotational effects of driving, cycles of warming and cooling and nudges from bumps in the road. Such stresses can cause a slight shift in the seating of the wheel nuts, which may result in tightening or loosening.
The presence of dirt, sand, rust or grit between surfaces such as the threads of the nut or between a nut and the wheel can also create “false torques” during the initial fitting, where the force applied overcomes the friction but doesn’t translate into clamping force.
I found one of my wheel bolts missing while cleaning the car. It had not long ago had a the tyre replaced so it was either not done up properly at the time or not even put back in. Too many numpties in charge of tools.
Just checked sizes and yes there different sizes but on opposite corners so looks like someones not paid attention while putting them back on after the refurb.
get a refund, i have been given a car for free so you can imagine what a heap that was and the wheels stayed on so i class it better than that dangerous car
Wheel nuts absolutely do come loose, even if torqued correctly.Not had that for a long time for either my bike or car. I think it was written on the invoice the first time I had my bike tires changed 7ish years ago but numerous tire changes on the car and bike since and it's never been mentioned.
They can write whatever they want on a bit of paper, it doesn't absolve them of negligence.
yes but for all they know the OP could have gone straight to the Nürburgring and worked them loose.
its in your own safety to check these things.
OP had done 90 miles since picking it up, he'd be doing well to get the the 'ring unless he lives there.
Well since its legally and scientifically proved that a perfectly torqued wheel can become loose within 25 miles, its very hard for you to prove negligence to the garage. Fair enough if you drive it out of the showroom and the wheel is wobbling around.
So if it says somewhere on the OPs paperwork that he should check the wheels after 25 miles and hes driven 90 miles, he wont have a leg to stand on.
And yet garages and dealers have been fined for this very thing occurring:
https://www.norfolk.gov.uk/news/201...-in-court-after-wheel-fell-off-car-on-the-a11
A correctly torqued wheel does not fall off. Cite your scientific sources please.
Correctly torqued wheel nuts are only correctly torqued at the time of fitting.And yet garages and dealers have been fined for this very thing occurring:
