MOARYOLO!!!!!!!
MOARYOLO!!!!!!!
You should probably get a 5800X3D Nexus, it seriously might help your 3080 with that 10GB frame buffer from those frame time spikes you get. I'm honestly not trolling you.![]()
Did you use anything to cover the SMD's or did you do a Matt?
From 12 minutes onwards in my video, you get some more mirror/metal/glass surfaces.
There are a couple of maps/areas further on in the game which are very orientated around reflections with all the metal but I think they might be a bit further in the game e.g.
If you are careful, no need for varnish or anything IMO, however I can understand why folks do it for peace of mind.The de-lidded 8700k I did couple of years ago I used nail varnish, this time I just put masking tape round the GPU and carefully added the LM then removed the masking tape.
In other words I did a LtMatt.
Is the LM slimy?![]()
I'll get to it at some point, but currently downloading a lot of different games and uploading videos to YouTube showing the performance of the 5800X3D.Not had a chance to upload video of that bit at the start yet @LtMatt ? Curious to see perf. etc. stats.
Found a 5800X3D running with a 3090 TI using DLSS at 1440P at the same settings. Seems to be noticeably slower, even with DLSS enabled.
Cool, was there any indication to why you where getting such awful temps with the factory fitted block.Junction 60 max and max on card temp is 42c
It has to be poor presure if there was nothing you could see wrong. You'll have to get 22.4.2 driver installed and give 3Dmark a bash!None at all, everything had good contact, too be honest I was getting really peev'd off as I was certain I would then refill the system to see exact same temps lol.
Bet that took a little wattage to get 23.5K graphics lol.
Not messed around, so this is stock lol. Just tinkered in the Radeon software settings.Bet that took a little wattage to get 23.5K graphics lol.
Power Limit Total: 332 W GPU: 320 A SOC: 55 ANot messed around, so this is stock lol. Just tinkered in the Radeon software settings.
