Deleted member 209350
There's no Trust anymore, check your profile for Feedback![]()
So has the way members market works changed now?
I would think that this allows the messages to be a decent size rather than squashing it alongside the avatar?
Yeh I've just added that to the listI note that quoting those large screengrabs that it doesn't minimise the image in the quote, can this be changed?
on the list to do!I note that quoting those large screengrabs that it doesn't minimise the image in the quote, can this be changed?
Thanks for your really helpful feedbackPreferred the old layout.
Screenshot please?
Screenshot please?
	It also used to be at the bottom of each page too. It was much more convenient to use that than scroll back up to the top when trying to get to a different forum section.To be fair there used to be an option in the tree Forum Index -> Life -> General Discussion.
Not a problem for me, just a slight change.
Click the Menu icon on top left and then you can get back to the index
When you open a thread, by default it takes you to the latest unread postSomebody may have already posted this, but when you open a thread, there is no "go to newest unread post" link anymore????
Top right corner - Are you not seeing a "Jump to new" button?Somebody may have already posted this, but when you open a thread, there is no "go to newest unread post" link anymore????
