- 21 Apr 2007
it probably hit its thermal limits fasterWhy is the 3090ti lower than the 3090?
...but when that 5% starts costing megabucks for no particularly good reason its just waste.Truth be told Nvidia are my go to for graphics cards, the same way Intel were for cpu's but I ended up with a Ryzen processor and would go AMD if they can provide the fastest graphics card.
I tend to buy the high end (pc gaming is my only vice) so even a part is only 5% faster it would be the one I'd go for.
AMD good Nvidia bad ok don't ask questions
6900XT: 18,463
6950XT: 22,209
22,209 / 18,463 = 1.20 (+20%)
How the #### did they do that?
3090TI: 20,855
6950XT: 22,209
22,209 / 20,855 = 1.0649 (+6.5%)
Strange lol. The 6950xt has no extra cores right? Just higher power limit and slightly faster vram
But if slightly higher memory bandwidth and higher power limit can boost it 20% then existing overclocked 6900xt must already be able to achieve the same scores
Edit: Yes 6900xt can already go up to 28k points
Ah but will we see those prices after launch?
it probably hit its thermal limits faster![]()
This score was likely taken before the radical Timespy driver improvements, hence the big jump with the new card.6900XT: 18,463
The real question is why is the 6900XT lower than either of them.
https://forums.overclockers.co.uk/threads/time-spy-standard-dx-12-bench.18740536/
As you can see from the bench thread it is a none contest.
I sometimes wonder how some of these tech sites do their testing.
I'm sure they will!Wonder if the amd store will have any...
To sum things up:
- RX 6950 XT vs RX 6900 XT = 4% Faster
- RX 6950 XT vs RTX 3090 = 11% Faster
The site that just keeps giving has some benchmarks - https://wccftech.com/amd-radeon-rx-...aster-rtx-3060-gaming-benchmarks-prices-leak/
Not sure why they bothered including FC6, the AMD cards score higher in it but the RT is half baked at best compared to Nvidia.
Still, the 6950 looks like a corker for non-RT gaming.
Is it? should we just take out anything where RDNA2 does well in RT because by your estimation AMD's RT is half baked compared with Nvidia?
Lets just stick to Control and Cyberpunk 2077 because those are the only true RT games.
