No need to be an arse about it. I thought it was a proven fact, rather than speculation.
Reddit - Dive into anything
www.reddit.com
Doesn't matter if its 1st gen to 2nd gen.... RDNA 2 is the best amd have to offer right now, ampere is the best nvidia have to offer right now, we are in the present here with lots of games already out with RT and only more to come going forward..... We have been getting RT titles for the past what 2-3 years now too? So it's not like this is a brand new of the block feature either....Still people comparing 1st Gen AMD RT to 2nd Gen Nvidia RT as though its a level playing field.![]()
When will it be allowed/ok to compare amd to nvidia for RT? When AMD catch up/beat nvidia in RT?
Besides, all a bit pointless comparing RT between the brands now imo, since RDNA 2 doesn't appear to even render RT properly/full in the first place.
In theory never as AMD will always be playing catch up. My point is the tired arguement keeps being brought up that Nvidia RT is better than AMD RT blah blah blah, yeah no ~~~~ Sherlock doesnt take a slide rule to work it out why! Come up with a better valid viewpoint bit like kicking someone when they are already down
In fact you said the same yourself !
I think a lot of it has to do with how the coding or software uses the RT cores, sure Nvidia's no doubt are overall stronger but not by the amounts some people like to point at, i think its more marginal than that, Control / Cyberpunk are games where the RT was never intended to run on RDNA2 RT cores to start with. People pointing at that and screeching "this is the real difference because these are real RT games" is ridiculous.
Anything that is Ray Tracing is 'real' Ray Tracing and there are a whole bunch of games now where the RT performance on RDNA2 is not too dissimilar to Ampere.
www.reddit.com
Can either of you provide a native screenshot from the benchmark sequence in FC6 at 4K maximum settings with a Nvidia GPU to prove the RT effects are not rendered properly on the AMD side?It is a fact. End of
I don't know about fc 6, haven't looked into it but it is happening in several titles (in bang4bucks footage and in his comments, people have also noted the same) and also the new unreal engine 5 city demo, posts on that in this thread, last page:Can either of you provide a native screenshot from the benchmark sequence in FC6 at 4K maximum settings with a Nvidia GPU to prove the RT effects are not rendered properly on the AMD side?
I will then copy the screenshot you provide for a direct side by side comparison. I am interested to see if there is any merit in this claim as it's the first I've heard of it.
From looking at the reddit thread, the whole claim appears to be based on a compressed YouTube recording, using each vendors encoder as the source of the image quality comparison.
Please correct me if I am wrong with the above assumption.
Can you provide a native screenshot rather than compressed videos? FC6 would be ideal since I have that installed already.I don't know about fc 6, haven't looked into it but it is happening in several titles (in bang4bucks footage and in his comments, people have also noted the same) and also the new unreal engine 5 city demo, posts on that in this thread, last page:
Unreal Engine 5 Pathtracing
Matrix demo called City Sample is now available to download on PC. https://unrealengine.com/marketplace/en-US/learn/city-sample City Sample file size is 86.5GB. :eek: Yeah, straight after posting here I saw a thread in the PC Games forum. Felt… unreal :cry:forums.overclockers.co.uk
Appreciate it if you can. If it's a genuine issue it can be reported.Admittedly I’ve only gone by the images posted but it looked pretty clean cut to me.
If I didn’t live in the sticks with a meagre 16Mb download speed I’d reinstall it and see. In fact I might do but not until everyone else has gone to bed or they’ll all be complaining that the internet is broken again.
Compressed?Can you provide a native screenshot rather than compressed videos? FC6 would be ideal since I have that installed already.
Yes, a true native image would be needed to show an issue. Not a screenshot of a video recorded using software, then compressed via YouTube. Hopefully HRL can provide that and we’ll see if it’s a genuine issue.Compressed?
Wouldn't say we're talking about awful quality here.... not to mention, both are being captured the same way and either way, compression is not going to remove that kind of detail....
I don't have fc 6 anymore but could do most of the other RT titles on show there except for the unreal engine demo.
Don’t know but a native image will confirm either way. If it is a genuine issue it will be present on a native image as well as a recording using software and then uploaded to YouTube.Do you really think compression would remove this kind of detail though?
Bearing in mind, that if so, it should also be happening with nvidia too?
Is it? should we just take out anything where RDNA2 does well in RT because by your estimation AMD's RT is half baked compared with Nvidia?
Lets just stick to Control and Cyberpunk 2077 because those are the only true RT games.
