EZ Bench (next gen Unreal Engine 5 Benchmark)
6 Feb 2019
New UE5 benchmark available for free on steam
It's a big 20gb download I thisnis because the benchmark uses 8k textures. You need at least 8gb VRAM
Recommend specs for running:
Requires a 64-bit processor and operating system
  • OS: Windows 10/11
  • Processor: 10th Gen Intel (or AMD equivalent)
  • Memory: 32 GB RAM
  • Graphics: RTX 3000 Series (or AMD Equivalent) with at least 8GB VRAM
  • DirectX: Version 12
  • Storage: 25 GB available space
PS5 Console Potato Mode:
PC (We're gonna need a bigger GPU) Mode:
Please test the 5800X3D in this.
Don't think it would make any difference, it puts hardly any load on the CPU, i don't have a 3090 but i doubt any none 3D cache would bottleneck it. My CPU is up and down between low power and boost states in this.
My CPU was running at 34c during this test it hardly works it. 6900xt was stock. Not that impressed with it as it glitched a few times. Timespy works my GPU harder. Although you can run around on the island when it finishes.
Come on guys, more plebeian level GPU's please, the scum corner is getting lonely over here.
Does it need RTX support? If not I'll run it on my 1070 later.....maybe even my 780ti for lols!
edit: just looked on the steam page and GTX 1080 is the minimum req.
I'll try it on the 1070 later but I'm guessing the keplar card is a lost cause :cry:
something odd with the scoring.. example:
Score 22910 on my 5800x3d with 32gb 4x8gb 3600mhz cl14 ram, 6800xt stock
and,
score 12250 on my 1800x with 16gb 2x8 3200mhz cl 16 ram and 5600xt stock.
Update
score 16850 on my wife's 1700x with 16gb 2x8 of 3200 cl 16 ram and a 5700xt stock
There is no way a 5700xt scores more than HALF as well as the 6800xt does.
