I missed that bit? Has she submitted two beating photos that are the same?
Bit of a commute to just call her a liar and throw poo at her though...
I've wondered about metadata (appreciate it's easy to fake). Are they being submitted with no metadata? Surely that in itself shows the pictures have been edited. Every modern phone and camera sets metadata on by default.
@mrk just need you to be called up as expert for photography hey![]()
Yup, you're right it can be modified but then the file properties would show that too because the file modified time/date would differ from the modified exif data showing when the photo was taken. Technically both file create property and exif metadata should match as the capture time is the same time as the image file being written to storage.
Basically every photo taken with a digital camera has two areas for properties, the basic file data itself which every file for anything has, which among other things includes Date Created and Date Modified, and for photos, EXIF data which includes the original date taken (assuming the date and time on the camera were set correctly) along with GPS data if available and exposure settings/copyright info etc etc.
The three Date related properties between file properties and EXIF should match up. Some metadata can be modified after the fact, but there would ve signs of modification when looking at the metadata in detail generally.
To be fair, I'm amazed that they haven't brought someone in to prove the photos are the same, particularly when they said exactly that to Heard and she denied it.
Just shows they are identical in subject as I didn't even spot it change.The image posted by mrk #954 is a combination of the 2 photos she submitted as evidence, claiming they were taken at different times of the day. One of the images was very flat, the other the saturation had been ramped up to highlight the redness on her right cheek.
at this point there's little need. there's an overwhelming amount of other stuff that makes edited photos just about irrelevant.To be fair, I'm amazed that they haven't brought someone in to prove the photos are the same, particularly when they said exactly that to Heard and she denied it.
