Hi!
I've currently got a Macbook pro 2017 which has reached the end of its shelf life, and I need a new laptop for work.
I don't want to use virtualisation anymore like I did with my Macbook, as I do a lot of Windows dev, so I'd like a Windows machine.
It would probably be connected to an external display and used in clamshell mode quite a bit.
I spend a lot of time programming and need plenty of RAM (I think around 16gb), a 1tb SSD, and I want it to be really snappy opening things like:
- SQL Server managment studio
- Multiple browser windows
- IIS instances of websites
- Multiple Visual Studio windows running multiple IIS express websites
- Couple of spreadsheets
- Slack chat client, maybe MSTeams as well
Graphics card isn't really much of a consideration as long as it's capable of powering my monitor - a LG 34" 34WN780-B.
USB-C would be good, as I'll be hot-desking at work, and they have displays with keyboards and mice plugged in which then connect to laptops.
For reference, I'm happy with the spec for my main desktop PC in terms of doing all this stuff, which is the following spec:
- AMD Ryzen 7 5800X 8-core
- 32gb RAM (I can cut this down a bit, I accept I don't need this much in a laptop for development)
- WD Blue SN550 1TB SSD NVME M.2 2280 PCIe Gen3
- MSI MPG B550 Gaming Edge WiFi (AMD AM4) B550 ATX mobo
- RTX 3080Ti (Definitely doesn't have to be anything like this - Onboard graphics would probably suit anyway wouldn't it?!)
Budget is ideally under £1,000 but I reckon could get my boss to stretch to £1,500. I'm happy with Ryzen or Intel, but Ryzen seems to be a lot cheaper.
Any help's appreciated, as always!
Cheers!
K
 - Onboard graphics would probably suit anyway wouldn't it?!)Budget is ideally under £1,000 but I reckon could get my boss to stretch to £1,500. I'm happy with Ryzen or Intel, but Ryzen seems to be a lot cheaper.
Cheers!
K
