Caporegime
You spent far too much time posing that
Don't think we haven't noticed the crank position, the stick blending into the woods holding up the bike, the wheel logos at the same position on the wheels.
Such a poser
So I’ve got £1,200 to spend, I’ve been looking at the below, can’t seem to find any reviews on it?
Is there anything else I should be looking at before I pull the trigger
Thanks!
Vitus Sentier 29 VR Mountain Bike 2022
Yeah, you got meYou spent far too much time posing that
Such a poser
Yeah, you got me
Miffed I left it in such a low gear, would have liked the chain parallel.
Hi buddy, my budget is 1.2K max I don't see a VRX in that price range?Have you considered the VRX? Few left on CRC. Fox Fork, SLX Chainset and Brakes, DT Swiss m1900 Wheelset.
It wont have changed much if at all since the 2020/2021 bike... have a look at reviews on those
Just get a Bizango Pro from Halfords, medium is in stock they are cracking bikes for the money.Actually there is the below model in my price range?
Vitus Sentier 27 VRS Mountain Bike 2021
Great shout, I had somehow missed this? I popped to my local store "Letchworth" and they had no idea when it would be back in stock, nor do they offer a pre-order on it so all I can do is watch their website!Just get a Bizango Pro from Halfords, medium is in stock they are cracking bikes for the money.
Voodoo Bizango Pro review - MBR
Since winning our 2022 Hardtail of the Year award, life has been good for the Voodoo Bizango Pro. So good, that the only thing that’s changed is the price has crept up by £25. Impressive, given that a bag of groceries has probably gone up by the same amount. Best hardtail mountain bikes...www.mbr.co.uk
*edit* not till next Month but worth tapping up your local store and booking one in.
Just an idea, but a mate of mine just took delivery of one of these today - https://www.planetx.co.uk/i/q/YBTIFLGX/titus-fireline-sram-gx-titanium-mountain-bikeGreat shout, I had somehow missed this? I popped to my local store "Letchworth" and they had no idea when it would be back in stock, nor do they offer a pre-order on it so all I can do is watch their website!
By their size guide I'm a large (5'11") so that's what I'll be looking out for!
Appreciate the shared link, I’ve already put my voucher through to my HR department, it’s £1,250 just a few pound over my monthly budget! Thanks again thoughJust an idea, but a mate of mine just took delivery of one of these today - https://www.planetx.co.uk/i/q/YBTIFLGX/titus-fireline-sram-gx-titanium-mountain-bike
It is £1500, but what a spec for the price, it is a lovely bit of kit and Plant X do R2W. Just an option before it goes back up in price to £2200. It is a proper trail bike so might not be what you are looking for.
Any reason the polygon from go outdoors doesn’t get mentioned here? is it that bad or? Didn’t they build the Bossnut years back which was well reviewed
Well my £1,250 voucher is in, trouble is all the bikes I like in that price range Voodoo Pro, Vitus, Nukeproof all seems to be out of stock or not in my size rangeThought that was calibre who made the bossnut or have they renamed themselves? Haven't heard much from them. They were considered the best full suss under £1k for a while there.
Polygon bikes get good reviews as far as I know.
5’11”?Are you very short because those bars and dropper suggest you are but the frame doesn’t. Have you checked the seat post width as well.
The same bike is 855 at Chain Reaction currently. Also could consider the 2021 Nukeproof Scout 290 Race at 999 (better wheels, grips better than your additional ones there and I think the fork is slightly better - Recon RL vs Recon RL Silver - but they may just be the same thing).
Nice bike. Have you looked at the Ghost - 12sp not 10sp?
I thought CR and Wiggle were the same company?The same bike is 855 at Chain Reaction currently. Also could consider the 2021 Nukeproof Scout 290 Race at 999 (better wheels, grips better than your additional ones there and I think the fork is slightly better - Recon RL vs Recon RL Silver - but they may just be the same thing).
Worth getting a longer dropper though for sure, 125 is short by todays standards - run a 170 on my main bike and it could probably fit a 200mm if I wanted. 31.6mm is the correct diameter though for either bike above.
Stock bars are decent enough and can be cut down if too wide.
Edit - with a £1250 budget, you could look at the Sentier VR at £1125. Marzocchi Bomber fork is a leap above the Recon, comes with a dropper fitted, better drivetrain too. Only seems in stock in 275 currently though.
