How have I missed this thread?. Unreal work fella and a few memories popping back into the head too, my wee brother had a gamegear when they first came out and almost instantly broke the charging module physically and had to use a never ending supy of batteries to play sonic and f1. I've worked in IT 20 odd years, repaired laptops etc but always shyed away from anything that needs a magnifying glass, I'd really wish i'd taken the time to learn it properly tbh.
I wait with baited breath, I have no doubt you'll smash that out in no time. Have you got a Raspberry Pi to hand to get a console out of the router?
Ugh dont, the only thing I have that needs repair right now is a Dell Precision 5520 that sparked out and needs something on the mainboard. No idea where to even start.It's hidden away from all the rif raffIt's never too late to learn. I learn mostly by just attacking stuff and seeing what happens.
@drakulton - Any update on the 1070?![]()
Currently doing trials with the original rajintek double sided thermal tape until the silver cement turns up. When I first tried the tape it was absolutely rubbish, as the heatsinks were dropping off the GPU as I was installing it in the PC. I took some of the sinks and tape to work and got them fixed quite firmly only after warming the parts up with a heatgun. They don't mention melting the tape in the rajintek instructions.
Ahh good stuff, do you fire it up and see it was posting fine on your machine?
Just a quick blast with an intel block plopped on it with the PC inverted.
Great news! Hope it doesn't give you to much trouble.@Finners - I have me an MSI Armour![]()
Does this card fail to post? I don't see any shorts on it at all! Resistance on vCore looks a little low.... Im thinking I might need to plug this in and see what its doing.
I will boot it and check all of its power rails later... Looks like a possible low resistance on vcore issue (which could be something as simple as a resistor on 5v detect). Wont be able to tell without measuring it while it has power going to it. Will need to check if all of its power rails are coming up we should be able to see 5v, 1.8v, 12v etc at the coils which is fairly simple.... Ill update on this one later... I can tell you it isn't a common fet issue, but something much more interesting!
Will commandeer the wifes machine tonight and poke it with the pointy sticks.
If I rememberly correctly it will post in a machine but with no image, if you have the sound on you would hear the windows log in noise.
If I put it in a second slot, I think it was visible in device manager put had an error on it.
Way hey, look at it go. Seriously impressive stuff, you must have a very steady hand!
