Wiring in new double socket
19 Oct 2017
I wanted to wire in a new double socket from an existing double socket. So I was going to split the line with a 30A junction box and attach new cable to a double socket for an electric fire place.
It looks straight forward but is there anything I should be aware of or anything I should be taking into consideration?
28 Dec 2017
Beds
Firstly check whether the existing socket is part of a ring. If it's a spur you can't extend that. You can make a single spur off of a ring. As this is for a heater and not something low energy, I'd stick to the regulations.
Beyond that, common sense prevails i.e. place the socket in a permissible location, use a decent connection method (junction box or wago will both work), etc.
OP
19 Oct 2017
Thanks for the reply’s I have seen those wago boxes but just like the look of a three-way junction box. The plan was to spur it into a 2 gang switched socket with an rcd just for the extra protection because its a heater.
Is there a good way to check if it’s a ring circuit ?
18 Oct 2002
Bedfordshire
One way to tell is the rating of the circuit breaker. A ring will most likely be 32 amps. Another option if you have an EICR it will tell you in there.
You could also look behind the existing socket, if it's on a ring it will have a 2.5mm twin and earth coming in and 2.5mm twin and earth going back out.
If that's the case then you can run a third cable from the socket terminals to your new socket, no junction required.
If you only have one cable coming into the existing socket then it's a spur already, which as above you cannot extend, or (less likely) it's the end of a radial.
OP
19 Oct 2017
I will have a look at the socket and the circuit breaker.
When you say run a third cable do you mean add the new socket into the the existing ring circuit or do you mean run a third cable form the old existing socket ?
Many thanks
18 Oct 2002
Bedfordshire
Run a third cable (2.5mm twin and earth) from the existing socket, by doing this you'll be creating a spur on the ring.
By the way, I haven't tried these yet but you can get screw less sockets now which should make this kind of job a breeze.
edit - this video might be helpful https://www.youtube.com/watch?v=8a9yNLxBj-M
14 Jan 2018
Hampshire
If your circuits are not already protected with RCDs then you are not legally allowed to do this work yourself.
14 Mar 2005
Here and There...
I’ve been hoping someone would make a socket like that for ages! It is such a pain trying to squeeze up to three wires into the same terminal hole and the inevitability of putting your screwdriver down and not being able to find it at the key moment! I shall be buying some of these!
21 Sep 2020
I bought the 5 pack and added a couple of extra sockets in my garage and front door cupboard. They’re bloody excellent and take seconds. It takes longer to screw them on. Knowing that each one is torqued perfectly as well is such a game changer.
Just be a matter of time before they start doing screwless ones in black or chrome.
14 Mar 2005
Here and There...
They’ve said if they are popular they will expand to the full range of items too so we will get light switches, fused spurs etc really would make a massive difference!
21 Sep 2020
Would be epic if they did, imagine the time saved doing full houses or office buildings etc be incredible. It’s ones of those where we really need sparks on commercial jobs to be using them to get the sales up - price probably means we won’t see it sadly even though the saving in time is for all to see.
Sorry for the derail!
4 Dec 2002
Bourne, Lincs
Just fitted our new kitchen with these utter game changer, Dad called them cheating lol but yeah pay the extra quid or so and get these so much easier to wire up sockets.
9 Apr 2007
Odd that it only accepts up to 4mm. All mine are 6mm so they wouldn't work for me.
