- 25 Oct 2005
Although I’m thinking now, if I’m using the ISP router, is there any much benefit from using Ubifi controller software at all?
What exactly are you planning on using the controller software to do beyond the initial config and periodic update of AP firmware?Although I’m thinking now, if I’m using the ISP router, is there any much benefit from using Ubifi controller software at all?
I thought I had read somewhere that you needed it running all the time, so if it was on a pc, the pc would need to be on all the time. I think I must have got confused by someone saying that if you want to be able to constantly manage them via the controller software, then you’ll need it on all the time.What exactly are you planning on using the controller software to do beyond the initial config and periodic update of AP firmware?
If you want it running all the time you could create a free VM in Oracle Cloud, it's pretty straight forward to set up and install.
Choose the arm Ubuntu image and either install the controller in a docker and also run Adguard Home as an example or run it native. There is a two command Controller installation script which makes things super easy. Buy the guy a coffee if you use it as he is constantly updating it etc.Will have a look at that
wget https://get.glennr.nl/unifi/install/unifi-7.0.25.sh
bash unifi-7.0.25.sh
No, they process the VAT on behalf of HMRC.Ordering from EU store i'm charged VAT, but I thought VAT was charged at delivery now? Am I going to get charged twice?
Anyone know what is going on with the Unifi Switch stock? I placed an order for a 16 port ages ago. I haven't seen them come in stock anywhere and used prices are crazy.
It's a great time to be flogging off any old 48 port PoE switches you have that are passably useful though, people are desperate
Any 16 or 24 port by any chance? My little 8 port is full with a second 8 port connected to it.Now you mention it, I have a few Gen1 switches that I've kept for no good reason so now may well be the time to move them on.
In theory, I have two US-16-150W switches and a USW-24-PoE Pro Gen2 but they are in Edinburgh and Lowestoft and I'm in Flint in North Wales. So not this week at the earliest.
Plenty of places have the USW-16-Lite in stock if you need one quickly.
