*** The Car Cleaning Thread ***
Status
Not open for further replies.
Amazing colour that needs to be spotless to appreciate. Any dust or dirt and it looks rubbish.
so what did you get ? :)
Garage Therapy /ONE: Car Shampoo (V2) - 1000ml
Fulfilled 15 Jun 13:33 Parcel Force #UK2415014
Gar201046504£17.001£17.00
Tiger Edgeless 400 Long/Short Pile Microfibre Cloth - Grey
Tig190869430£1.501£1.50
Tiger Edgeless 400 Long/Short Pile Microfibre Cloth - Blue
Tig190869415£1.501£1.50
Koch Chemie Fse - Finish Spray Exterior - 1000ml
KC285001.1£10.541£10.54
Korean Microfibre Twisted Pile Drying Towel - 74 x 90cm - Orange
MFTWISTTOWEL_ORANGE£10.991£10.99
in2Detailing Transparent Wash Bucket with Gamma Seal Lid
B4F-5FF-472£18.952£37.90
Bilt Hamber Auto-Mitt (Noodle Wash Mitt)
Bil210368217£11.951£11.95
Angelwax Cleanliness Concentrated Orange Pre-Wash - 5000ml
AW_Cleanliness_5000£24.751£24.75
Only forgot to order a turbine dirt lock for my bucket.
Guys
im cleaning tomorrow (not the car, my utensils)
i have microfiber detergent , but what about the brushes ?
im just going to use fairy liquid to make soapy water, that will be alright wont it ?
Just put a drop of your MF detergent in a bucket and small amount of water. Then work the brushes with your fingers (or if you have a clean grit guard, put that in at the bottom and work the brush against it) to get any muck from between the fibres.
I personally use Surcare detergent for MF, cheaper than dedicated ones from the car care brands. Others also recommend Woolite too.
ECP has some heavy discount on Autobrite 500ml products.
Heard good things about AB Cherry Glaze so figured worth a punt at £4.99
Also picked up 3 bottles of AF Purple Rain 3.0 for £4.97 each as well as Purple Velvet Shampoo.
Status
