- 20 Jul 2007
- A sunnier or damper area than Ron-ski....
Hi folks,
Just posting as a few requests/IMs from another thread for my 3d printed cable management solution.
Background:
In terms of cable management under my desk, got fed up with:
So my solution needed to be:
imgur.com
And I've started replacing all these annoying cable runs:
imgur.com
As you can see - ticks all the above boxes and costs next to nothing to 3d print!
Free STL:
drive.google.com
Welcome any builds, thoughts and ideas - happy to print some for anyone without a 3d printer. Goodness know you've all helped me enough over the years! (just IM me).
Now maybe I just need to work out how to add the OCUK logo onto this.... I like the idea of OCUK-branded underware
Background:
- sticky pads under my desk that kept falling off after a while
- solutions that 'bundled' all the wires together, that just become a mess of cables after a while
- some had 90 degree edges that started to wear cables after a while
- non-reusable solutions - ie cable ties that you need to cut and replace everytime.
- some also had hinged clips that covered multiple cables, which is great until you want to take a cable out and you have to release all 5-6 cables at the same time
- screw mountable - so no more falling off
- individual cable mounts - so it keeps cables separated, easy to access/swap and nice and tidy
- No sharp edges on corners - no wearing of cables
- Universal fit - ie fit everything from a 13amp cable to a speaker cable
- 3d printable without supports or any faffing
imgur.com
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
imgur.com
Free STL:
Ultimate Overclockers Cable Tidy v3.stl
drive.google.com
