Hi all! I built a PC a few months back and have had an issue since I built it.
When I start the PC in the morning, it will start without issue (although the last few days it has started slowly?) and after about 5 minutes, the whole PC freezes to the point where it needs a hard reset. This happens almost every day. There was about a few weeks where this didn't happen and it is now back. I really am not sure where to start with it because I don't have the ability to swap out parts.
I am seeing some errors in my event viewer previous to today's freeze. I'm not sure if anyone can advise if these could be the cause. Please let me know if there is a better way to show this info.
I started the PC at 8:59 and got a few of these at 9AM:
The speed of processor 19 in group 0 is being limited by system firmware. The processor has been in this reduced performance state for 71 seconds since the last report.
The speed of processor 18 in group 0 is being limited by system firmware. The processor has been in this reduced performance state for 71 seconds since the last report.
x 4 in this instance.
at 9:01 I got:
Session "NT Kernel Logger" failed to start with the following error: 0xC0000035
9:02
Unable to open the Server service performance object. The first four bytes (DWORD) of the Data section contains the status code.
9:03:
The backing-file for the real-time session "NT Kernel Logger" has reached its maximum size. As a result, new events will not be logged to this session until space becomes available. This error is often caused by starting a trace session in real-time mode without having any real-time consumers.
9:03
And then it froze at 9:06?
I have tried a full reinstall with no luck.
PC:
Device name DESKTOP-8T53BG7
Processor 12th Gen Intel(R) Core(TM) i7-12700K 3.61 GHz
Installed RAM 16.0 GB (15.7 GB usable)
ASUS Intel Z690 ROG STRIX Z690-A GAMING WIFI D4 PC
Asus GeForce RTX 3060Ti Dual OC V2 LHR 8GB GDDR6 PCI-Express Graphics Card
Not overclocked
Any help would be fantastic! I'm at a loss on this! :')
at 9:01 I got:
9:02
9:03:
9:03
PC:
Not overclocked
