The one I have now is the Ryobi RY18LMX40A-0 18V ONE+ Cordless 40cm Brushless Lawnmower@samcat what model do you have? I'm at the point of kicking my petrol mower every time I see it hoping it'll fail, it's getting on now but the decent Ryobi's aren't cheap. They had one in B&Q and it felt like a toy.
www.yardforce.eu
I know my makita one you plug in two batteries (2*18v=36v) and its not an issue with 5AH batteries18V Ryobi is the saddest POS ive ever owned.... Lasts 5 mins tops on 5amp battery. Overheats all the time meaning have to change batteries constantly and wait for them to cool.
Its on par with a childs toy.
It might be ok if you are literally trimming mm off your already well kept lawn.
You need more volts 40v minimum id say.
Which one for context? As they have quite a few and the more expensive ones are well reviewed.18V Ryobi is the saddest POS ive ever owned
