Man of Honour
- 21 Nov 2004
Met office putting next Sunday at 34C now for us. Those temperatures are creeping up. Who knows by then.
It doesn't mean it doesn't happen, it just means if you got better, more efficient chillers, it happens less.I have visited a supermarket opened less than 12 months prior and staff were in a rush to empty the freezers.
Let's hope this doesn't come off:
Every run is trending that way and the min temps aren't far behind... other models seem to be following though the BBC is going against.
I've not looked at what those who actually know what they are talking about are saying yet but the setup leading to it seems to be dragging considerable heat up from the south where temperatures are breaking records so...
EDIT: Though it looks like there will be a fair bit of breeze which will hopefully offset the brutality of it.
What I'm reading is 'I need to move Scotland'.
On a completely random note, catteries in the UK are required by law to have portable/fixed air con available to ensure the cat housings don't go above 26c even when outdoor temps do (to prevent the cats from overheating). I always found it comical that what are legally defined as wild animals must be kept cooler due to the regs than they would be in the wild.Most counties in the south east of England have a threshold of 27C, while many central areas of England and south-east Wales have a threshold of 26C.
RIPCurrently 34° here, with 38-39° forecast from Wednesday.
Where abouts in France? Was down South last week and it was between 29-36, got quite used to it in the end, so nice to feel comfortable in shorts and t shirt at night.Currently 34° here, with 38-39° forecast from Wednesday.
I have worked in offices with no air con, tiny windows which made zilch difference to the temperature. Every time reach out, get paper stuck to arms.Yet for humans the law is only that work place temperatures have to be "reasonable" without any real clear definition...
Had it 43c in Vendee in 1990. About this time of July tooWhere abouts in France? Was down South last week and it was between 29-36, got quite used to it in the end, so nice to feel comfortable in shorts and t shirt at night.
Wow thats mad, did you like it?Had it 43c in Vendee in 1990. About this time of July too
