Caporegime
- 1 Dec 2010
- Welling, London
Job lot of salad for mon and tue I think. I can’t be eating hot food in 36 degrees
36? Forecast 39 here currently...Job lot of salad for mon and tue I think. I can’t be eating hot food in 36 degrees
It will drop by the time I have dinner36? Forecast 39 here currently...
I never switch mine off. Why would you need to.Who here still has their heating still on
No way am I barbecuing when the temps in the high 30’s. BBQ weather is 22-30 degreesYou're kidding? This is BBQ weather if ever I saw it!
Presumably you have a good thermostat?I never switch mine off. Why would you need to.
So how is that model of ac you gotPresumably you have a good thermostat?
Yet it’s a lot hotter than last year when 1600 people died because of the heat.Why do we have a red weather warning for this weather. What is the "risk of serious illness or death" that the met office are on about. Its just a bit of warm weather.
Doing nicely thanks. Will get its acid test next week though. It will have to go some to keep the room cool in 39 degrees.So how is that model of ac you got
The hose gets quite hot if you can insulate it even better just make sure the seal is good and do not buy a extention for it the btu rating goes lowerDoing nicely thanks. Will get its acid test next week though. It will have to go some to keep the room cool in 39 degrees.
Presumably he's just set it to only come on if the temps drop below 25c, like I do on summer, so it's effectively turned off.
I'll be having a chilli on Monday and a roast on TuesdayJob lot of salad for mon and tue I think. I can’t be eating hot food in 36 degrees
