THANK you sir. You are the first person to dare test, I applaud you.ran it a 2nd time and it got higher:
score 11927
More than 15kcrikey. what does the 12900k with 6 cores at 115w get?
(i use 115w since my cooler handles it well for temps/noise)
More than 15k
Can get more if i reset my memory to defaults but im bored of retraining afterwards
Thats what i keep saying, the p cores are phenomenal and probably going to beat zen 4 in efficiency as well. Its the ecores that are terrible cause intel decided to clock them way outside their efficiency point.thats impressive. @Vince can you run the threadripper at something like 65w and see how it scores?
Well not sure, cant test it now since i left my house. Considering it gets 16200 at 65 watts, id assume 18-19k, maybe more. Ill test when I get backwhat sort of score would it get at 115w with all cores unlocked and not restricted to 6?
With ecores on im sure zen 3 can match it, cause as I've been saying ecores are pretty bad at efficiency. 8p + 8e is less efficient than 16 zen 3 cores (unless you drop to less than 80w total). But 8p vs 8zen 3 cores, its a slaughter.well thats settled then. unless anyone with a 5950x can run some benches too at different wattage points it looks to be a clear win for intel in efficiency and if the above figures are correct with the 12900k getting around 23k at 115w then even i too doubt zen4 can match that.
I posted an ss from fc6 at 25watts 100 fps gpu bound with a 3090![]()
AMD's Ryzen 7 5800X3D Draws Less than Half as Much Power than the Intel Core i9-12900KS and Yet Faster in Gaming Workloads | Hardware Times
AMD’s Ryzen 7 5800X3D is now available for purchase at retailers across the world. Pairing 64MB of 3D stacked L3 cache (overall 96MB) with the mature Zen 3 CCD results in the fastest gaming processor which beats not only Intel’s Core i9-12900K but the recently launched $749 i9-12900KS as well...www.hardwaretimes.com
Isn't this what we should be looking at in terms of efficiency. I don't play CB-R23. I play games and so what watts it uses when gaming is relative between CPUs.
Right so you have posted one thing about one game but stock out the box performance for multiple games is as linked etc. Being efficient out the box and running games as per the stock settings should be the base. Running something at 25watt is irrelevant. I am home tonight so can put my 5950x at 25watt for FC6 and my 6900xt and see what I get if you want but I don't have a 3090 and other factors would be involved unless you happen to have an AMD CPU to normal that is worthless info.I posted an ss from fc6 at 25watts 100 fps gpu bound with a 3090
Cause Intel doesn't exist anymore, they don't have any products there
But you are just wrong. The e cores are WAY less efficient than the Pcores at same clockspeeds. I mean I can test it for you, the ecores are absolutely atrocious in everything, BUT performance per die space. That's what they are good at. The proper comparison is 1P cores vs 4E cores, since a P core takes the die space of 4 ecores.
Again, as everyone before you, you keep saying it's not efficient, but no one provides some 8 core zen 3 numbers so we can compare....
Just to add - Please don't bother replying. I can't be bothered with the argument.
I do find it really odd when you get people who are normal home users sat behind a keyboard, arguing with people who work in the industries where it is your job to know about all of this. Literal hands on everyday use with things they'll never get a sniff at, but nope because they bought a CPU in box, and can watch YouTube they are right, so don't be arguing!
Did you seen the link I posted in the EPYC thread btw Vince, with the leaked Genoa benchmarks?
6 gc cores can match that score at 45-50w. Here is my run at 55
