- 24 Mar 2019
Got my first quote in. For all 3 bedrooms and the living room.
3 x 1.6kw units
1 x 2.5kw unit
1 x 2.5kw external unit
Daikin
£4400![]()
Daikin Air conditioning Multi 1 x 4MXM68A 4 x FTXP20M9 2Kw Wall Mounted Heat Pump R32 A+ 1Ph
Daikin Air conditioning Multi 1 x 4MXM68A 4 x FTXP20M9 2Kw Wall Mounted Heat Pump R32 A 1Ph 240V 50Hz A max pipe run 60M This Kit Includes 1 xwww.orionairsales.co.uk
Panasonic
£4000Free Multi - TZ super-compact
Wall-mounted TZ super-compact Compact and elegant design with only 779mm wide.The perfect air conditioner for the smallest spaces in your home (including the limited space above a door). With PM2.5 filter and built-in Wi-Fi.www.aircon.panasonic.eu
Midea
£3600.
Thinking of the Panasonic as it has a 7 year warranty Vs 5 for the others.
We have just had a Midea Xtreme Save 3.5kw installed to replace a knackered Electriq split for £1k and its ok for the money. But, the outdoor unit never seems to modulate down that much, even at night, whereas the other unit the fan was barely spinning. And this one hums badly through the wall, even though it is mounted on a dedicated mounting bracket. I think i might get him to drop it to ground level so that it has less contact with the brickwork.
We are also looking to have our bedroom unit replaced and an additional unit installed in the lounge directly below. We are thinking Daikin 2 x 2.5 kw for and a 4kw outdoor unit for both rooms which are around 20m2, although they do have big windows. I would go for 2 x 3.5kw units but i would also need to spec a bigger outdoor unit to cope with the additional loading, plus the 3.5kw we have in there at the moment, when it was new, it was almost too cold!
Or does anyone think a 4kw outdoor would be ok on 2 x 3,5kw indoor units?
