Old AMD CPU's ?
19 Oct 2002
Pembrokeshire
I am trying to help someone with a computer build with some bits they were given which appear to be quite old:
The system has a motherboard a Gigabyte GA-78LMT-USB3 R2
On the motherboard there is an AMD CPU : AMD FX FD8350
However in another box we found another CPU : AMD Ryzen 3 3200G
I've no idea about old AMD CPU's and was wondering which of the above is the best CPU (they want it to play some games) and if it is the 3200G does it work in the motherboard they have.
Thanks
Pick up a cheap A320 motherboard (less than £30) and go with the 3200G ? Then they won't even need a GPU, It won't set any world records but for the small cost...
I might upset some people on the forum as the FX8350 (strangely) had many fans on here, but I consider it to be one of the worst chips of the last decade. Terrible single core performance coupled with atrocious power consumption. The worst combination. Your friend won't thank you for using one in a build after the October power price increases. Imo the chip is a complete non starter.
The good news: You should still get nearly £30 for it on the auction site. Enough for a board for the 3200g.
The better news: The 3200g is a great chip for office PC work and older/indie gaming. A new A320 board won't need a bios update unless its been sitting on a shop shelf for >2.5 years. It might be worth sending questions to 2nd hand sellers to find out what bios revisions they have. They sell for about £20 delivered.
You can run the 3200g with its integrated graphics on a picopsu /90W power brick £20 combo. Its integrated graphics performance is about 75% of a last gen console. Power use in windows doing office work will be <30 watts.
Thanks both, I'll pass this info on and see if they want to go the 3200G route.
One last thing. You can get A320 with display ports, but are pretty rare? So most are going to be HDMI 1.4 ish? So no 4K 60Hz. Or 3440 2K ultrawides.
And I've just checked the new motherboard prices. They've gone through the roof in the last month.
