I buy a litre of IPA at a time, it's a good all a round cleaner and always good to have, you can get a bottle for just over £7. I use mine as a record cleaning solution that is mixed up in a spay bottle, so get through a bit more than most people.go the chemist and ask if they have any alcohol pads people use to clean their skin before an injection, you can probably get some for free if you claim your a heroin addict or some such
will be a fraction of the price for the "computer" related version thats exactly the same
They probably are as effective but probably way more expensive per application.I'm planning to repaste my overclocked 6700K/GPU and ArctiClean fluid was the one to use to clean the surface but now there are cleaning wipes from the likes of Noctua and Arctic but are they as effective?
