- 21 Jul 2005
- Officially least sunny location -Ronskistats
Again, looking through other threads to find posts to push a narrative which aren't the point of the thread. Thought that wasn't allowed?
I don't see any reason why we need any more than 4kb of RAM. Got us to the bleedin' moon.
Oh, I don't doubt that, but they would be contemporary arguments, comparing like with like. 4k demands in 2015 would have been far lower than 2022.Same could be said for plenty of other examples i.e. power consumption/heat of the 290s compared to nvidia, tessellation etc
I was talking about GTA V specifically in that quote which has been brought back from the past btw. Guess that was the only thing that could be found.Oh, I don't doubt that, but they would be contemporary arguments, comparing like with like. 4k demands in 2015 would have been far lower than 2022.
To be clear I'm not saying matt was right then - I have absolutely no idea. But it's not a relevant quote to use in this argument in my view.
Also, I've downloaded Far Cry 6 on the epic games launcher to try the benchmarks and gameplay at 4k, see if I still have the same issues. I don't seem able to download the HD pack though, the store is locked on the free trial, and I can't seem to find it? Probably being blind.
I realised it was a bit of an old one!I was talking about GTA V specifically in that quote which has been brought back from the past btw
Isn’t it free this weekend on Uplay? Not sure how to downLoad it via Epic, maybe there is an option some where inside the Epic app for an optional download?It's not there in game and the store button in game is also greyed out, but I also can't find a way to download it either as I have it installed via Epic rather than ubisoft.
Not that I could see. I'll see if I need to download it via uplay instead of epic. That'll be a pain...Isn’t it free this weekend on Uplay? Not sure how to downLoad it via Epic, maybe there is an option some where inside the Epic app for an optional download?
I can’t see That being possible.Not that I could see. I'll see if I need to download it via uplay instead of epic. That'll be a pain...
The consoles didn't sacrifice anything, the developers did. If you stuck more power in the consoles the developers will just stick more stuff on screen and then turn down the resolution or framerate to make it work. Unless public opinion changes, don't expect the next generation of consoles to hit a stable 60fps and/or 4k resolution.@Chuk_Chuk
Interesting post, what's your thoughts on the current gen consoles having to sacrifice various graphical settings (obviously RT is pretty much a complete no go [usually will mean 30 fps lock if you want to use them] but also the normal settings having to be reduced as per DF in depth analysis game reviews) as well as running at resolutions lower than native 4k just to hold a locked 60 (PS 5 is usually around 1400p and xbx is about 1600/1800p). So far a 3080 10gb doesn't have to make these compromises quite to the same extent.
Also comparing a £650 graphics card to a £500 fully kitted computer with peripherals. I damn well hope it doesn't need to make the same compromise.
If we were talking about the 3060 or maybe even the 3070 with 10GB of VRAM. I would agree that it is enough (for now). But we are talking about the flagship card for PC gaming (assuming AMD drops the ball).
You're paying a premium so that you can have the same graphical fidelity as a console, admittedly with higher frame rates. (I think we all agree that an increase graphical fidelity, compared to the console, will require more VRAM right? Does anyone disagree?). Like i said on the first page for those that buy a new graphics card every generation this isn't going to be a problem. For anyone planning on skipping a generation, good luck with that.
I'm not sure if I'll be upgrading yet as it depends on price performance but if nvidia dangled a 4080 for £650 that was 30% faster than a 3090ti but only had 10gb VRAM and the next up was £1400 then I'd probably bite.Bill. Most people that bought the 3080 intend to keep it for a while. These characters stirring **** and posting fail threads like the one here are obsessed with it and make freudian slips.
Nobody has bashed the card it will be dead on for the majority of users such as yourself. As HU and other tech channels still report, when your spending lots of money on a premium product there is no need to skimp on the hardware, it certainly isnt costing nvidia much money to honour that.
But would you be able to launch/play FC 6 @ 4k with no FSR and max settings?I'm not sure if I'll be upgrading yet as it depends on price performance but if nvidia dangled a 4080 for £650 that was 30% faster than a 3090ti but only had 10gb VRAM and the next up was £1400 then I'd probably bite.
Gasp! You promised we could!But would you be able to launch/play FC 6 @ 4k with no FSR and max settings?![]()
I'm not sure we have learned anything then
True but then nvidia had nothing under £1400 with more than 10gb ram at release last time, if it was the same scenario again this time then I'd still go for 10gb as spending over double isn't worth it compaired to just tinkering with a few settings now and again although I would expect 10gb to struggle in more games over the next two years than just the one we had this time around.I'm not sure we have learned anything then, things that could eradicate the concerns would be better compression or some other edge feature like RTX IO which assisted in preventing choke. Also if you had a quality 1440p display and were not changing it anytime soon, then again that would be a good choice in your hypothetical scenario. No problem with that.
So to reiterate, unless something comes along to allow less vram to be needed in the next gen of cards, when your shelling out £600+ on premium products the amount that looks like the sweet spot for high resolutions, frames , ray tracing etc. seems to be around 12GB.
Must admit
ray tracing
This is fun.is just ******* useless
Few understand.True but then nvidia had nothing under £1400 with more than 10gb ram at release last time, if it was the same scenario again this time then I'd still go for 10gb as spending over double isn't worth it compaired to just tinkering with a few settings now and again although I would expect 10gb to struggle in more games over the next two years than just the one we had this time around.
This is fun.![]()
